Harman AVR 4550 - speaker match?!!
Discussion in 'AV Receivers & Amplifiers' started by Nik1967, Sep 17, 2004.
  1. Nik1967
    Nik1967
    Jun 22, 2004
    52
    hi all,
    will the Harman AVR 4550 be a good match for B&W'S 600's S3 speaker system? Will it bring out the best from these speakers? How would it compare with a Marantz SR 5400 OSE?
  2. recruit
    recruit
    Hi Nik,
    I used to own an AVR5500 with B&W 602.5 S3 as fronts and the 600 s3 at the Rear's and the sound was very good indeed so i would presume the 4550 would be just as good if not better.
    John :)
  3. Nik1967
    Nik1967
    Jun 22, 2004
    52
    thanks John. You seem to have a totally different set-up now. Any particular reason for changing the HK/B&W combination?
  4. recruit
    recruit
    Hi Nik,
    I have been changeing thing's for so long now but am finally content with what i have now.
    The H/K amps are very good though and would definetly recommend them, i nearly bought a HK avr8500 but settled for the new Yam Z9.
    John :)
