Hardware request
Discussion in 'Projectors, Screens & Video Processors' started by lonestar, Mar 18, 2003.
Thread Status:
Not open for further replies.
  1. lonestar
    lonestar
    Jul 26, 2001
    179
    maghera, n.ireland
    +3
    after spending some time reading through threads on this forum, I am very keen to get a home cinema setup going.
    My question to all is this, what do I need to connect my sky+, dvd, video and ps2 to a projector? A simple question but one I'm no doubt will produce a few different answers. If this is at all answerable then I welcome any feedback.
    Thanks.
  2. flibble
    flibble
    Feb 21, 2003
    72
    The one I have has,
    Composite Video
    S Video
    RGBHV (for pluging a computer in)
    RGB TTL (that I haven't worked out yet)
    Pluging a PAL or NTSC resolution source into a projector directly may not give the best picture, you would be able to see individual horizontal lines (there are only 500 odd in PAL). Using a line doubler or similar would look better, as it'll fill in the gaps.
    Peter
Thread Status:
