Hard Wired IR Extender
Discussion in 'Home Cinema Buying & Building' started by rtidrtid, Mar 7, 2013.
  1. rtidrtid
    rtidrtid
    Nov 16, 2008
    11
    3
    Hi all
    I plan to move my TV cable box out of sight, so i'm after a wired remote IR extender (around 10m). does anyone know where I can find one?
    I've tried amazon, ebay and maplin - and failed!
    Or is 10m too long?
  2. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    Why does it have to be wired, and why haven't you been able to find it?:confused::)
    There's a very wide choice of both types, that a Google search will find.
  3. ajbaker
    ajbaker
    Dec 27, 2006
    149
    +10
    I purchased this: IR LINK PRO - EBODE - INFRARED EXTENDER, PRO | CPC
    I have extended the IR receiver with a 20m CAT5e cable (the supplied cable was cut and I used choc-blocks to join to the CAT5e cable) - not elegant, but it got the job done and works perfectly.
    Andrew
