Hard Reset for Panasonic DMR-E95?
Discussion in 'Blu-ray & DVD Players & Recorders' started by MLS, May 25, 2005.
  1. MLS
    MLS
    Apr 7, 2005
    43
    London
    Can anyone tell how to do a soft or hard reset for this DVD/HDD recorder?
    I had backed up one of my DVDs with my PC DVD writer, but it failed just before the end of writing, so I inserted the disk into the Panasonic to see if anything on the disk was playable and now the whole machine has frozen!
    I have unplugged it a couple of times, but each time it went through a very long (more than two minutes) 'self check', and when the check was over the machine wouldn't respond to any buttons - not even the on/off button, or the eject button.
    Help please! MLS
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    468
    Hitchin
    +68
    Have you tried holding in the eject button while you turn it on?
  3. MLS
    MLS
    Apr 7, 2005
    43
    London
    Thanks Nelviticus - In fact, after being frozen for about ten minutes or more, I was eventually able to eject the disk normally. If it happens again, I'll try your suggestion. MLS
  4. Maximumbaz
    Maximumbaz
    Feb 10, 2004
    126
    Portsmouth
    It happened to me once, see page 60 of the manual. You have to press and hold the stop button and channel up button on the main unit for about 5 seconds.
