Hard Drive Space
Discussion in 'Headphones, Earphones & Portable Music' started by solo_1138, Mar 12, 2005.
  1. solo_1138
    solo_1138
    I've loaded a few albums onto itunes which are now on my ipod. Rather than buying a larger hard drive, can i just delete the albums from itunes without it affecting what's already on the ipod?
    Will the ipod tracks delete as well to sync with itunes?
    Solo
  2. HMHB
    HMHB
    Nov 11, 2001
    27,518
    Nottinghamshire
    +6,439
    If you've set it to synch then it will delete the tunes on your ipod as well.
  3. jon smith
    jon smith
    Jun 5, 2001
    3,568
    Leeds
    +230
    can you stop is syncing though so it doesn't delete the files that are no longer on the PC...?
    I want a 40gb IPOD, but I only have about 27GB left on my laptop so would need to delete some stuff from the harddrive once it is on the ipod.
  4. HMHB
    HMHB
    Nov 11, 2001
    27,518
    Nottinghamshire
    +6,439
    You can turn the auto synch off and do it manually.
  5. jon smith
    jon smith
    Jun 5, 2001
    3,568
    Leeds
    +230
    If you do manually sync I take it that files deleted from the PC are not deleted from the ipod as well then?
  6. HMHB
    HMHB
    Nov 11, 2001
    27,518
    Nottinghamshire
    +6,439
    That's the way I believe it works (but don't blame me if it doesn't!!). This is taken from Apple:-
    "In Manual Mode, you take total control over the contents of your iPod by dragging individual songs to create your own custom playlists. This lets you decide when to update your iPod, since it’s not affected by changes in your music library."
  7. jon smith
    jon smith
    Jun 5, 2001
    3,568
    Leeds
    +230
    Thanks for the info - don't worry I won't blame you :)
  8. weebroonieuk
    weebroonieuk
    Oct 30, 2004
    177
    16
    do you have 27 gb of music ? if you do , dont delete the files you have
    just burn them off do a cdr there buttons now or prefereably dvdrs just incase anything happens !
