hard drive problems
Discussion in 'Computer Components' started by sc1977, Feb 18, 2003.
  1. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    latly my IBM 60 GB deskstar hard drive has started clicking i have defraged it but it still does it when i use certain programs does any body know what this is?
  2. Desmo
    Desmo
    Jan 4, 2001
    13,423
    Braintree, Essex.
    +4,769
    Back up all of your important data NOW. Your hard drive is about to snuff it.
    Sorry to sound so harsh but it's a known problem with that IBM drive.
    [edit] You can look at this page to see a few problems and symptoms others have had.
  3. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    oh great all inportant stuff is on 40gb maxator any known problems and what should i replace my ibm with?:suicide:
  4. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    The Seagate Barracudas are very good and quiet.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    The later generation of IBM drive were renound for failure.
    What has happed ids you experiencing bad sectors on your hard drive and the noise in the reading arm getting stuck with the bad sector.
    Norton utilities can mark bad sectors so that the drive does not try to write to them but to be honest the price of hard drives now is so cheap (30Gig for £50) just go out and buy another and then transfer all the data from the IBM to it
  6. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    have used chek disk on windows xp and checked the fix errors box
    the hard drive dos'nt click so much now only rarley, any thoughts?
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    Seriously SC1977 dont wait for it to go bang. Start saving for a new drive. I have learn't the hard way and I wouldn't want the same to happen to you. Remember your data is the most valuable part of yor PC.
    YOU HAVE BEEN WARNED :)
  8. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    cheers for the advice mate i dont have anything of any importance on that drive so im willing to wait it out. the firm i work for has just gone into recievership so i dont know how long ill have a job for so spending £120 + on a hard drive is not an otion at the moment as soon as i know the score im gonna treat thr pc to a 120 gig maxator (all i do on it is browse this forum and download the simpsons )
