Hard drive in the Panasonic 85
Discussion in 'Blu-ray & DVD Players & Recorders' started by Canary Richard, Nov 25, 2004.
  1. Canary Richard
    Canary Richard
    Nov 25, 2004
    35
    Does anyone know the specification for the 80GB hard drive in the Panasonic DMR-E85H DVD/Hard Disk Recorder? Should it ever fail in the future and I need to replace it, I would like to know the spindle speed RPM. I suspect it is 5400rpm. Can anyone confirm this?
    From reading various message boards it seems important not to replace it with a higher spec drive which could cause problems with the amount of power required to drive it.
    I've emailed Panasonic UK but received a snooty reply saying that they won't tell me!
  2. Mikey45
    Mikey45
    It's not the power drawer of the drive but the firmware of the recorder limiting the usable capacity to 80Gb. I dare say the 120Gb or 160Gb version of whatever is installed just has 6 or 8 platters instead of the 2 or 4 of the original drive.
  3. Bosco
    Bosco
    The US version of the E85 has a 120Gb HDD, not sure whether it will work on the European models but I suspect not.
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If it fails, you should be able to see the drive make and model from the one in the machine. A problem might arise if the model or equivalent is obsolete by then. But I suspect any equivalent capacity drive the same size (2.5" or 3.5") would do.
