Please give as much information as possible.Help
Maxtor SATA 160GB HD has failed.
It has photos on that I would like to retrieve.
anyone help on this?
The drive is used as a backup, it made a few clicking noises then died.
The PC no longer sees the drive and I've tried it in another pc and it seems completely dead.
2nd time one of these drives has failed.
Shall stay away from Maxtor in future
Recovery prices are prohibitive
Will have to learn lesson next time.
Annoying thing is that I have 2 external HD's and I should have copied the files as a precaution
Thanks for your help
I had same problem. Its likely mechanical failure. Quite often its a bearing failure through wear. My resolution was to freeze the HD over night. Double bag it - leave it in freezer over night. Plug it into a spare IDE on my pC and recover what I could before the drive warmed up. I had to do this 7 times to recover 60Gb of data.
If you are wondering how it works? Tolerances. Metals reduce size and increase tolerances at low temperatures.
