Hard drive enlosure advice
Discussion in 'Apple Forum' started by Legacy, Feb 10, 2009.
  1. Legacy
    Legacy
    Jan 15, 2009
    104
    Lincoln
    +12
    I'm looking for a way to store all my media content to be easily accessible to my MacBook without having to build a file server or anything. I came across the idea of using HDD enclosures and am basically looking for some recommendations.
    Basically I need an enclosure that can hold at least four SATA hard drives, 1tb or more per drive would be ideal with support for different brand / size drives, and linkable to my MacBook via firewire would be great. I've had a look around the internet but am not really sure what I should be looking at with regards to brands, other features etc.
    Also, if there is a better way of getting a lot of media storage to my Mac, please let me know, thanks!
    (by the way I live in the UK, so any shopping links would have to deliver to the UK).
    Thanks in advance for any replies!
    EDIT:
    Looking around some more, this seems like a difficult thing to find without shelling out several hundred pounds, and that's without even having any storage space.
    So are there better ways to do what I want to do? I'm fairly new to the whole HTPC scene, but basically I just want to have a lot of storage and room for expansion accessible by my MacBook as opposed to having a whole separate system for handling my media. The main reason for this is because I think it will be cheaper, I don't want to have to build a PC (too much hassle), and I like using the mac OS and remote etc.
  2. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    Its a trade-off. The easy answer is get a Drobo but as you say its hundreds before any actual storage but it is scaleable easily. The alternative is to buy fairly cheap 1Tb drives and use a hub. The WD My Book USB range is fairly inexpensive (a 1Tb recently cost me £63 but £79 is more likely) and you can expand those as needed. Using the same but with firewire ports to daisy chain drives is roughly 50% more expensive but would be better, whether you want to spend the extra is up to you.
    There isn't really a cheap NAS that truly fits in between.
  3. Alistair
    Alistair
    Dec 1, 2008
    236
    28
    Gloucestershire
    +39
    Another vote for Drobo, but they aren't cheap.
