Quantcast
hard drive creak
every now and then i am getting a noise from my hard drive simular to a creaking door the drive is only a month old is it dying
Garrett
Was noise there when you installed it? Whatever I would make a backup of your important data.
no it was a new drive installed with xp by a shop
Garrett
No what I meant when you first got your drive last week.
I was talking to my mate earlier this evening and he said you want to worry when you can hear the head making a noise then hearing it making a banging noise (no smutty innuendos please).;)
cskates
Could well be the drive recalibrating itself periodically. As the drive heats up and expands, the track positions change and it needs to rescan the surface. What make and model is the hard drive?
it says its a "HDS722580VLAT20" IF THATS ANY USE
BlueOrange25
Not to scare you or anything, but I suggest you backup all your important data as soon as you can. Recently, I bought a Hitachi Deskstar 7K250 160GB SATA drive for my PC, and I experienced similar noises comming from my hard drive.
I ran the hard drive for roughly 2 months, occasionally hearing a 'creaking' or 'crying' noise, even though it was brand new.
Anyway, after 2 months the hard drive failed on me. I found that Windows no longer loaded up properly, even after I reinstalled the OS. The hard drive is now useless.:thumbsdow
Hitachi (formerly IBM) have had a bad reputation for hard drive reliability (the 'DeathStar'), and the current series of hard drives were supposed to change all that. :mad:
I'm not certain if what happened to my hard drive is the same thing that yours is going through. Just to be on the safe side though, get the drive checked out. Hard drives shouldn't make any serious noises, especially when brand new.
Hope it's just a minor problem mate.
amordue
I have a couple of "deathstars" that died, and were replaced, the replacement 60gb has been in my htpc for over a year now and has been making the creaking / crying noise for around 6 months. The only reason its still in the machine is I dont really care if it dies, as it just contains the os + dvd / multimedia playback software, that I can easily reinstall.
I've also had another 2 20gbs early model Deskstars that were out of warranty when they died.
Basically I wouldnt put anything you care about on there :)
Alex
Similar threads
