Hard Drive confusion.
Discussion in 'Computer Components' started by sapper, May 14, 2004.
  1. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    Hi all,
    I am in the process of shortlisting componemnts for a HCPC.
    My innitial aim is to use a small IDE hard drive (the smallest ive found is 80 Gigs for ~£45) to set up the system and to store the software stuff on.
    I am then intending to install additioanl RAId/ATA seraial drives to store the ripped Cd's and other data on. Is this feasible?
    How do I set up the system to ghost the data if I wanted to onto another drive?
    Whats this I have vaguel read about the larger drives being problematic to format, and being unreliable.
    Any help on this issue of hard drives would be most appreciated.
    Also using a wireless network, will i be able to access the drives etc from my current PC across the wireless network?
    How simple is it to set up?
    Adrian
