Hard Drive Car Head Unit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by frozendexter, Jun 10, 2005.
  1. frozendexter
    frozendexter
    Dec 18, 2002
    208
    The North
    Hi, sorry if this has been coverd before but does anyone know of any head units available that either use a removeable/fixed hard drive and flash media or similar other than the over priced Sony MEX-1HD.
    There was mention at some time of a company producing a head unit with a built-in HDD and WIFI capability for downloading tracks from your PC but this seems the have vanished.
    Cheers.
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
  3. MacReady
    MacReady
    Jun 25, 2003
    2,466
    3
    Barnsley, South Yorkshire
    +199
    There is the Pioneer DEH-P900HDD. 10Gb hard drive and Magicgate memory stick slot...but I think it retails at around the £1000 mark :eek:
  4. jonbd
    jonbd
    Nov 29, 2003
    343
    +14
    There is someone selling them on ebay at the moment with the smp3-c or dmp3-a for £174.99 all in, just bagged me one with the dmp3-c. You just have to add your own hdd in!
  5. as8602
    as8602
    Apr 15, 2003
    87
    +11
    How have you got on with this? Isn't this the head unit that can take a 2.5" HD as well as the external DMP3a? How much of a pain was it to connect to the external DMP3a?
  6. jonbd
    jonbd
    Nov 29, 2003
    343
    +14
    i got the one that comes with the internal 2.5" hdd. You put the HDD in the caddy and it slots into place in the front of the head unit, and you connect the caddy up to your PC to transfer files. It shows up as a normall hdd in windows so you can keep whatever structure you have for your mp3s, and can of course use it as a normall hdd. I don't have the dmp3a unit, thought it was a lot less convenient than the dmp3-c. Just waiting on a ISO to Ford wiring convertor to stick it in my car. Hopefully it will be here tomorrow so I'll give you the full low down then
  7. as8602
    as8602
    Apr 15, 2003
    87
    +11
    Great - look forward to hearing about it.
    I was originally very keen to buy a headunit with the 2.5" internal cartridge, but dithered a bit, and then they seemed to be discontinued in the UK (used to be able to buy them from DABS).
    Like you I felt that the integral HDD looked *way* more convenient. Though the external DMP3a does at least let you use a 3.5" drive, so you could have a 200GB drive for around the cost of a 2.5" 60 GB drive. Though the 2.5" drives are *supposed* to be more robust.
    I can't believe that this isn't a bigger market, as it really shouldn't be too expensive to produce the iPod for the car. But, I've also been mystified as to why no-one can bring out a FreeView PVR with DVD recorder - but that's another issue...!
  8. jonbd
    jonbd
    Nov 29, 2003
    343
    +14
    Well, installed the dension today. Took about ten minutes to take the old one out and stick this one in, nice and painless!! Sound quality is very nice and the dispay is very good, very clear and lots of info on screen. You can change the backlight colour as well! Operation of the unit for mp3s isn't all that intuitive, but i'm getting used to it and it works a lot better than any other system i've seen. All in all i'm very pleased with it!
  9. swampi1234
    swampi1234
    Any ideas where to get the Dension DH-100 from i've searched everywhere !!??
  10. jonbd
    jonbd
    Nov 29, 2003
    343
    +14
    only place i've seen is the guy that sells them on ebay. keep your eyes peeled, he usually has at least one auction a week
  11. as8602
    as8602
    Apr 15, 2003
    87
    +11
    Got mine yesterday and love the MP3 convenience.
    My suggestion to make navigation work well is to have an \artist\album kind of structure. Navigate to the album folder and press play to play the album, or navigate to the artist folder to play all their albums. Use random to play random tracks from the selected tree structure (so you can use random play for an artist's entire repertoire).
    From playing, the quickest way to get back and select something else is to press UP or DOWN which gets back to the folder tree, very quick to navigate from there.
    How have you found radio reception? Mine is pretty pants.
  12. ajfoggy
    ajfoggy
    Aug 12, 2004
    112
    +5
    I just bought a Alpine9847R and Alpine KCA-420i to go with my ipod, works a treat, sounds good and full control of ipod from headunit.
    Cost £210 delivered for Alpine kit, plus £170 for 40gb ipod.
    Maybe and option???
  13. tvr
    tvr
    Aug 21, 2002
    443
    Bucks
    +4
    Intersting thoughts on your Alpine combo ajfoggy.
    I had exactly the same set-up for a week. Found it unusable!
    The tedious scrolling through albums/artists/songs etc. takes forever!
    If I wanted to get to an artist beginning with letter 'm' for example, it could take a minute or two of constant rotating the knob to get there - it was SO SLOW! - and therefore quite dangerous I found.
    The solution I am happy with now, was a £10 cradle suckered to the windscreen, and a Monster charger/line out plug to line-in (aux) on back of the Alpine HU.
    This menas i get the same quality sound from the ipod, and retain it's fantastic functionality/display.
  14. as8602
    as8602
    Apr 15, 2003
    87
    +11
    And isn't the display on the Alpine a bit useless for displaying the track/artist info, as it looks like a very basic display to me. I get the feeling that this kind of integration is only going to work well when designed into the unit, with a decent display, rather than retrofitted to make the ipod look like another CD changer.
    Still can't believe there aren't more solutions for in-car jukeboxes.
  15. tvr
    tvr
    Aug 21, 2002
    443
    Bucks
    +4
    Yes it is on this particular HU. The more expensive Alpines HU's are better with much more display area etc.
    But no matter how much you spend on the HU, you cannot get round the tediously slow selection knob!
    Don't have first hand experience of the glide function. Not heard good things, but would like to see for myself.
    One other thing I dislike about the KCA is the fact it is always trying to charge the iPod, using up more unnecessary charge cycles.
  16. jonbd
    jonbd
    Nov 29, 2003
    343
    +14
    Yeah, that's how i have mine structured. FM reception is not great but gets the job done so I can listen to the footie, which is all I need
