Hard Disk Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by tspoon, Oct 14, 2004.
  1. tspoon
    tspoon
    Hello,
    I've read many article/messages here, and am seeking to purchase a Hard Disk DVD Recorder.
    Many people suggest the Panny E55, as an entry model, however when I search and read specs about this model, none of them mention the
    Hard Disk or the size of the HD.
    Can someone please tell me what the best 'entry model' is for around £200.
    I'd prefer some kind of HD with at least 20/30 hours storage. Nothing special. Not looking to burn Eastenders for my neighbour.
    Was just about to get a PVR, when I found out it does not record from SKY.
    Thanks for your help,
    Terry
  2. Chandy
    Chandy
    hi. i believe the E55 does not have a HDD. the one with the hdd is the E85.
    someone please correct me if i'm wrong
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    that's right, no hard disk on the E55.
  4. bobbles
    bobbles
    iirc the cheapest you are going to find a HDD DVDR is £360 ish. Well worth it mind you.
  5. tspoon
    tspoon
    Do you know what make and model type that would be?
    Or rather, what spec's can I be looking for aroun the £300 - £400
    Thanks for your prompt replies
  6. F G Evans
    F G Evans
    For that type of money you can get the excellent Toshiba RDXS32 - regarded by many as the best HDD/DVD recorder on the market at present.
    It does everything you could possible need including having the most versitile and flexible recording features.
    The Panny 85E is also a good choice.
    Most readers will fall into one of these camps.
  7. tspoon
    tspoon
    Hello again,
    thanks for you info. The main thing I'd like to know about either the Toshiba or the
    Panasonic, is that, do they allow you to record from SKY. If not then I don't really see the main benefit of only being able to record from terresterial. If the Toshiba can record from SKY to Hard Disk - then I will def prompt for the Tosh.
    Much appreciated feedback
  8. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    All DVD recorders will record from Sky (now someone will name a model that doesn't), certainly the ones you are considering do. The only thing you have to watch for is that some don't record in RGB.
  9. bobbles
    bobbles
    the tosh will control your STB to change channels on timer recordings too. Very useful for people without sky+
