A guy at work has a fujitsu laptop and has been having problems with it. He had the hard disk replace under warranty but this didnt cure the problem.
Every so often the computer freezes and when it reboots it gets locked in the BSOD and then the boot screen.
If you run chkdsk it gets to about 60% and hangs.
He ordered a new hard disk which I installed about 2 months ago. he came in this morning with the same problem.
I can format and reload XP from his back-up disk but he obviously has a problem somewhere as this is the third hard disk thats failed.
Any ideas whats causing the problem.
