Happy with my Iscan apart from...
Discussion in 'Projectors, Screens & Video Processors' started by azzo, Jul 5, 2003.
  1. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    I have just purchased an Iscan pro from another forum and
    been pleased with it over the past few weeks, however I
    am getting 'dropped' frames, about 2 per film. Is this 'normal'.
    the dropped frames last for about 1 second when the display
    goes dark grey.
    Is there anything I can do about this?
    I read from past posts that museumsteve had the same problem,
    but that was caused by his amp switching, although I was using a switch box this is still happening without it.
    Thanx in advance
    Azzo.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    A dropped frame is 1/50th's of a second. So you have something more serious.
    What are your sources, what is the display. Is this obvious with DVD only or with other sources.
    Gordon
  3. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Hi Gordon,
    Ok, so its more tha a dropped frame, (Probably 25 frames!)
    Happens with DVD, PS2, GameCube under component
    and so far have tried PS2 under S-Video and it still happens.
    I am using a VGA-VGA cable and have not had problems
    like this without the Iscan.I am using good quality cables
    and its going to the infamous AE100.
    I had begun to think that may be something in another
    room is interfering like a fridge, but I have plugged it into the cooker circuit by itself and it still happens.
    I play the same scene again when it happens, the scene plays fine.
    Thanx,
    Azzo.
  4. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Bump.
    Anyone?
    Does anyone know where I can get help with this product?
    I have emailed owl and dvdo and neither have replied.
    Azzo
  5. JUS
    JUS
    Jan 21, 2003
    3,433
    Plute
    +320
    Spent a while investigating this myself. Some VGA inputs aren't good enough for video. Just designed for computer signals. My Z1 drops frames as well. If you change to a VGA-Component lead you will be fine. You may lose a little bit of detail compared to the VGA feed but at least you won't get a headache!
    After being a member of this forum since it started (acct got deleted recently) I've finally arrived. I've answered a question Gordon couldn't :clap:
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    So you think you're smart then......What's the capitol of Bolivia?....and no cheating by looking it up mind!
    Gordon
  7. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Bogata? Straight off the top of my head though, so I bet it's wrong!
    EDIT:- Damn! It wasn't, won't spoilt is for the others but I'm miffed as I saw a facinating documentary of the architectural history of this place a few months back. Should've know. Guess I'm not that smart... Mind you, I never claimed I was :D
    Mark.
  8. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    La Pas.
  9. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    JUS YOU ARE SPOT ON.
    I actually made a hybrid lead up on Sunday and have spent all week testing it. So far now dropped frames. I was going to post this after more testing as I actually haven't watched a film all way through yet. Good to know the Iscan is working as it should. Not supprised that this is another bug in the notorious AE100.
    Thank you so much for confirming this.
    Azzo.
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Azzo it's not just AE100's that suffer from this. Other big name devices prefer to be fed through their component inputs as well
    Gordon
    La Paz...indeed....
  11. JUS
    JUS
    Jan 21, 2003
    3,433
    Plute
    +320
    :D :D
    I'm sure I would have been able to tell you that.... Clough. :rolleyes:
    So why is this Gordon? I don't really understand why the VGA input would not be able to cope with this. I realise most PC applications don't scroll but alot of games and educational software does. Is it just a money saving thing?
    Also, there are loads of people that use PC for HC and I've never seen this reported before. Which really does surprise me.
    Jus.
