Happy landings
Discussion in 'Past Entries' started by newbie1, Aug 13, 2018.
  1. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Selfies are really not my thing but I've given it a go and taken inspiration from all the people at the airport here on Skiathos doing the same thing :)
    EXIF 17mm (shifted up), f16, 1/2000th ISO 1250
    [​IMG]skiathos_2018 by Good Lux Photos, on Flickr
  2. The Dreamer
    The Dreamer
    Jul 7, 2006
    1,887
    146
    Not where I want to be!
    +3,036
    Brave chap - standing under an F70 of that vintage!
    In fairness they’re pretty reliable, and it’s not often that bits drop off!:D
  3. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Happy to report I’m still in one piece :) who’s up next? A bit thin on entries this month?
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,864
    33
    Glasgow
    +25,824
    C'mon - you didn't think that he was actually there do you ? ....that's why he looks like he's just standing in front of a background and stuck on..... :devil:
  5. 273K
    273K
    Dec 7, 2009
    1,158
    116
    Merseyside
    +1,235
    Good entry. What does (shifted up) mean?
  6. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Shifting up controls perspective distortion. I’ve tried similar shots with fish eye and super wide angle and the problem is that standing close and pointing up in the sky to get the plane and the ground in results in heavily distorted verticals. The tilt-shift took care of it very well. See perspective control section in the article below.
    Tilt–shift photography - Wikipedia
  7. 273K
    273K
    Dec 7, 2009
    1,158
    116
    Merseyside
    +1,235
    I see so is that built into the lens or done in software?
  8. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    It’s possible to correct perspective distortion with software like Lightroom. In this case it’s so extreme I found it doesn’t work.
    A tilt shift lens shifts the center of the lens up and down and I find much more effective solution. This is what I used for the photo no additional software correction needed.
    Here is the lens I used - looks quite different to other lenses due to the controls for tilting and shifting Canon TS-E 17mm lens - Wikipedia
  9. 273K
    273K
    Dec 7, 2009
    1,158
    116
    Merseyside
    +1,235
    Is the tilt-shift controlled manually? I wouldn't mind having a go with one but they're pretty expensive/rare.
  10. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Yes it’s manually controlled. No autofocus. Picked up mine second hand. You could try renting to test one out for much less.
