Hannspree TV vs Hanns.G Monitor
richardhsm
I’m confused by the Hanns.G and Hannspree branding. Very.
I’m looking for a cheap 27” monitor as I can’t afford the 2560 x 1900 I want till the prices come down or technology obsoletes them.
There are two 27” screens marketed by Hanns.G/Hannspree in the UK – they appear technically identical. One is marketed at the TV sector with a Freeview Tuner & the other at the Computer sector (no TV Tuner).
The Hanns.G HZ281 HPB is the unit focussed at the Computer User. It is some £260.
The Hanspree ST281 MAB is the unit focussed at the TV/Home user. It is some £210.
Go figure. :eek:
The units appear identical, except the company has ripped the Freeview Tuner out of the Hanspree; called it a Hanns.G fiddled with the model number and added £50 to the price ?
Am I cynical & wrong ? Please advise.
:lease:
Thx - Richard
Hannspree ST281 MAB
Display Size 28" (27.5" viewable)
Resolution 1920 × 1200 (PC Mode: 1280 × 1024)
Aspect Ratio 16:10
Display Colors 16.7 M
Brightness 400 cd/m²
Contrast Ration 10000:1 (X-Contrast)
Response Time 5 ms
Viewing Angle 170° (H) / 160° (V)
Input HDMI × 2 / YPbPr / Composite / SCART × 2 / VGA (PC) / Tuner
Audio Built-in Speakers (10W + 10W)
Swivel No
Kensignton Slot Yes
VESA Mounting Yes
Power Consumption 60W (Typical)
Standby Power Consumption <1W
Certificates CE, CB, GS, GOST-R, WEEE, RoHS, Energy Star 3.0
Net Dimensions 672.2 (W) × 516.5 (H) × 190 (D) mm
Net Weight 8.87 kg
Remarks Selections and specifications may vary by country.
Hanns.G HZ281 HPB
Display Size 70cm Wide (27,5") (16:10)
Panel Type Active Matrix TFT
Brightness 400 cd/m² (typ.)
Contrast (typ.) 800:1
X-Contrast (dyn.) 15,000:1
Pixel Pitch 0,309(H) x 0,309(V) mm
Resolution (H x V) WUXGA 1920 x 1200
Response Time 3 ms (GtG)
View Angles LR, UD H/V 170° / 160°
Display Colors 16,7 Mio Colors
Color Warm, Nature, Cool, User Mode
Display Surface Anti-Glare
Input 1 VGA Analog, PC Audio
Input 2 DVI-D (HDCP)
Input 3 HDMI 1,3
Speakers 2 W x 2
Supply AC 100~240V, 50~60Hz
Consumption On: 95W; Stand-by: < 1W; Off: < 1W
Operation Temperature/Humidity 5 ~ 35°C / 10% ~ 85%
Dimension (W x D x H) 653 x 254 x 523 mm
Net Weight 8,5 kg
Tilt 0°~ 20°
Kensington Lock Yes
VESA Mounting VESA Standard, 100mm
On Screen Display EN, TC, DE, FR, ES, IT, PT, NL, SC, JP, KR, RU
Certification CE, CB, GOST, 3C
Emission MPR II
RoHS (2008) Yes
Windows 7 Yes
Extras 1 Black glossy frame
EAN 4710859557001
Accessories Cable (Power, VGA, DVI-D_HDMI, Audio), Quick- Start-Guide, User Manual (CD)
mikka23
Im asking the exact same question. Interested to see if anyone knows the answer. I was looking for a monitor and was deciding between these two.
richardhsm
The man at Hannspree in Hemel Hempstead doesnt want to be quoted verbatim. But he says to all intents & purposes the units above are identical, their existence as different model numbers (the casing is different) owes more to the company's branding policies & marketing structure than anything else. Panel technology is the same at this end of the market, there are few panel manufacturers...the same technology thus appearing in ' all ' brands.
LG SP11RA Soundbar Review Coming Soon to AVForums
