Hannspree JT2 37E2
Glen3337
Hi All:hiya:
Just got this Tv :D, Picture is excellent compared to my old crt,
Sound needs some tweaking to get bass right?
Anyway does anybody know the best settings for the picture....?
Some channels look great while others look dark/with to much colour..
also is there a sky remote code out there...?
Cheers Glen:)
xP I Deja Vu
HANNspree say in their FAQ "
Question -Does my SKY remote control support Hannspree TVs?
Answer -
Sky (BSkyB) Remote controls do not support 'the volume' control on Hannspree TVs currently. The remote controls have
been analyzed by Sky and a corresponding code has been generated. However it will be available with SKY's next update
which is scheduled at the beginning of 2008. Essentially the Sky remote control can be used for all purposes other than '
Volume' control. The remote control supplied with the Hannspree TV will need to be used for 'volume control' purposes
on the Television.
Hope that shone some light :)
nwgarratt
With regards to the picture. It will take about two weeks for the LCD to settle down and a slight fiddle with the settings might be required. Other peoples settings are not much help as it depends on peoples preferences, room lighting, location of TV etc. Not every channel is going to look as good as each other.
