MarkQuinton
Hi all
I've looked around an cannot find a definitive answer.
I would like to hand a 32" LED/LCD tv from an internal wall. However this internal wall has no studs as it it is filled with a honeycomb type cardboard, I believe this is called Pararmount walling.
Can I hang a tv on this directly or would I need to cut out the facing plasterboard and somehow add some battens. This would not be easy as even if I add battens the only thing I can secure it to is the plasterboard so I'm not sure if this would help at all.
Any ideas?
Mark
Any ideas?
Mark
