Quantcast
Hanging DIY screen
Jim McC
What is the easiest/best way to hang a DIY screen made of 1X3 poplar and blackout cloth? Weight is maybe 30 lbs. All fasteners must be hidden on rear. Thanks.
Peter Parker
I used two small pieces of the wood the screen was made from (about 6ins long), and fixed them to the wall about a quarter way in from each side.
The screen frame hangs on like a picture, and can be slid side to side for any minor adjustments if needed.
HTH
