hanging a plasma
Discussion in 'Home Cinema Building DIY' started by andy2322, Sep 1, 2013.
  1. andy2322
    andy2322
    Mar 28, 2009
    2,180
    cardiff
    +217
    hi i'm looking for a new tv to replace my old GT50 that fell off my unit.
    so i'm looking at putting it on the wall but my wall is a dot and dab plasterboard is it possible to do this
  2. Nickffc
    Nickffc
    Dec 21, 2011
    274
    Terrington St Clement
    +14
    depends on what the dot and dab wall is fixed to...? is it solid wall behind....brick or breeze block...?
  3. andy2322
    andy2322
    Mar 28, 2009
    2,180
    cardiff
    +217
    It's the outside wall brick
  4. turbozilla
    turbozilla
    Feb 22, 2013
    13
    Yes yes and yes. My 60" is on poxy plaster board!
    Our solution was to 1st mount 1/2 ply to the downward battons and then the bracket to this, tbf the srews were pretty long.
  5. NickParks
    NickParks
    May 1, 2012
    326
    32
    Colchester, Essex
    +35
    Do a search for Rigifix, sounds just what you need - the anchor goes into the brick/block work behind the plasterboard so there is no pressure on the plasterboard -
  6. MassiveJim
    MassiveJim
    Aug 13, 2006
    165
    +17
    I used rigifix bolts to hold my 46" plasma to the wall (dot n dab onto breezeblock) and I am quietly confident that I could actually hang off the bracket. Although I haven't actually tested this.
  7. andy2322
    andy2322
    Mar 28, 2009
    2,180
    cardiff
    +217
    anyone know what size gap i've got between a dot & dab to house brick? i want to use rigifix but not sure if i can use
  8. MassiveJim
    MassiveJim
    Aug 13, 2006
    165
    +17
    rigifix is designed FOR dot n dab. The gap is normally standard depth as the plug sockets need to sit flush with the plasterboard. But other than you measuring the gap how are we supposed to know the gap ?
    and what makes you think you can't use rigifix ?
  9. andy2322
    andy2322
    Mar 28, 2009
    2,180
    cardiff
    +217
    I had problems with my insulation and when the company came they put a camera into the wall and said the distance...
