HAMA 5345 CABLE RELEASE ADAPTER
Discussion in 'Photography Forums' started by icemanonline, Feb 21, 2014.
  1. icemanonline
    icemanonline
    Sep 4, 2006
    7,339
    Edinburgh
    +2,466
    HAMA 5345 CABLE RELEASE ADAPTER ??
    I have a Sony Nex F3 among others and its a great camera but Sony in thier own wisdom left out a connector for a cable release or IR even though you do have the option to use BULB in full maunal............but no way of using a cable release :facepalm:
    So, I have been looking at either making or adapting a bracket or "L" bracket or some such thing to try and use the BULB function.........and found this!!
    Any users? :smoke: I mean this strap and cable release........Think at £11 its worth a punt?
    [​IMG]
    Comments of advice from all you Blue Peter kids :lease:
    ice
  2. BubbleDouble
    BubbleDouble
    Jan 13, 2009
    4,227
    2
    Space
    +1,883
    Never seen a cable release as whacky as that before. It's like it's from a time before electronic shutter releases. Found a review here. There are more reviews on Amazon, but they don't seem favourable.
  3. icemanonline
    icemanonline
    Sep 4, 2006
    7,339
    Edinburgh
    +2,466
    Cheers,
    Wonder if using an L bracket with added onconnection for a cable release would work! It must be possible to buy a metal version of the screw in ppart.......then maybe cut and tack a bit of metal with the metal screw connection in place!
    Mmmmmm. Might try that.
    Any other ideas?
    Ice
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,585
    25
    Glasgow
    +25,577
    something like a small lightweight "C-Clamp" with a drilled/threaded hole to add a screw in cable release to might be a better option ?
  5. icemanonline
    icemanonline
    Sep 4, 2006
    7,339
    Edinburgh
    +2,466
    [Cheersquote="shotokan101, post: 20373303, member: 381681"]something like a small lightweight "C-Clamp" with a drilled/threaded hole to add a screw in cable release to might be a better option ?[/quote]
    Cheers Jim
    The f3 has an angled shutter so would have to take that into account to.
    Never understands why Sony do dumb a$$ things like this.....but still give the bulb option.
    Ta
    Ice
  6. icemanonline
    icemanonline
    Sep 4, 2006
    7,339
    Edinburgh
    +2,466
