halo effect on 9986
Discussion in 'LCD & LED LCD TVs' started by garytreble, Sep 1, 2005.
  1. garytreble
    garytreble
    Feb 3, 2005
    116
    +9
    As a general rule I'm very happy with my Philips 32PF9986. However, I’ve started noticing a 'halo' effect around images usually people. I noticed it quite a lot when I was watching the cricket last week.
    Is this normal behaviour from LCDs? OR is my set faulty?
  2. knowley
    knowley
    Jul 18, 2005
    82
    9
    Probably normal if its a digital signal from the BBC...
  3. garytreble
    garytreble
    Feb 3, 2005
    116
    +9
    yes, the signal is from a sky box. Can this be improved in any way?
  4. freekbear
    freekbear
    Don't know about the 9986 specifically, but it can be a picture processing artifact. Anything from mpeg-artifacts (high compression) to sharpening type filters - try disabling your picture plus, movie modes or any other processing. Try a different source.
  5. knowley
    knowley
    Jul 18, 2005
    82
    9
    Not sure on the Sky signal, but freeviews BBC channels aren't great - maybe its my ariel to some degree but I've seen topics on BBC freeview in here before.
  6. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    Sky, Freeview, Cable etc all excessively "edge enhance" many programmes which causes this effect. It looks awful, even on a CRT, but is easier to see on an LCD as it makes it easier to pick out fine details. (and flaws, such as this)
    Make sure you have your "sharpness" setting on the TV set to 0 as well. :)
    I hear the Philips "Pixel Plus" processing can really help an image, but will occassionally add even more artifacts like that to the image.
  7. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,532
    Woking, Surrey
    +44
    turn pixel plus off, I have mine off all the time because i hated the halo'ing.
  8. garytreble
    garytreble
    Feb 3, 2005
    116
    +9
    OK, I'll turn sharpness down to 0 & PP2 off & report back.
  9. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    OR. If you find the picture too lacking in detail without the PP2, run in Movie Plus. This is my favourite setup.
    Jimmy
