Halo 2, slow rendering (old xbox?)
Discussion in 'Xbox Forums' started by Kaz, Nov 15, 2004.
  1. Kaz
    Kaz
    especially during video footage between levels, I get really bad stutters, textures arriving late, even whole layers of image being rendered 1 second after the scene starts.
    Is this happening on your version? Mine's quite an old xbox. Have they put more meaty hardware in more recent ones?
  2. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    No, if anything it is more likely to be your xbox dvd drive diening on you, there are three types of them, samsung, phillips and thomson, the latter being the best. The latter is known to die around 1 year of use - although this does of course vary, however you can buy new dvd drives for around £40 off ebay or xbox-scene.com forums.
  3. jerkyboy
    jerkyboy
    This happens on ALL Xbox's.
    If you go to Bungie.com they have a Q&A page and this is one of the topics.
    They say its to do with the fact that they have no load times, so the Xbox is doing everything on the fly and sometimes struggles to keep up.
    It was this or put up with long load times.
  4. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    Don't panic, nothing's dying. Your xbox is fine. According to Bungie - Halo 2 streams everything from the DVD and hard drive so that's why we're all getting popups.
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,316
    Bristol
    +7,899
    I was wondering about this also, at least I know there is nothing wrong with my xbox.
  6. Gary D
    Gary D
    Jan 9, 2002
    7,784
    +838
    Kaz, i bought my xbox 5 days after release two and a half years ago. I've just finished Halo 2 (sunday) and i had none of the oproblems you mentioned.
    As for newer xboxes being "more upto date" while some minor changes may take place - the basic spec will always be the same thats why its a console and not a PC :D
    Gary
  7. Azrikam
    Azrikam
    Yeah, I've noticed the "fill in" effect on many of the cutscenes. It's not a big problem, but if you're looking for it, it can be distracting.
  8. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Agreed, it is distracting once you've noticed it, and it does look a bit crappy IMO. Is this partly due to a lack of specialist texture programming expertise at Bungie, or just down to a slow bus/ram in the xbox itself?
    I don't recall any of my other xbox games suffering from it as badly as Halo 2 does. I mean, its flippin' atrocious :(
    DT
  9. Rob20
    Rob20
    Jul 3, 2004
    3,078
    +658
    Do the newer XBox's have faster dvd drives? :confused:
  10. Zapp.Brannigan
    Zapp.Brannigan
    Jul 14, 2003
    169
    Manston, Ramsgate
    +3
    I have also noticed the rendering issue with H2.
    What bothered me though is when you first start playing the game, when you are being escorted around by one of your comrades. If he turns around to face you, he seems to physically "stutter" whilst turning around. He gets there eventually, it just looks like he's had to many espresso's!
    Another thing is, one on of the levels, some of the sounds (specifically the weapons) became really muffled. This lasted till the end of the scene. It was almost like shell shock!
    Has anyone else seen (heard) this? Is it meant to be like this?
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    Vacuum
    I've not had any popup problems. My Xbox is brand spanking new ( got rid of my chipped 120G HD version just to ensure Halo2 played fine).
    Unfortunately I get stutters if I feed 60Hz xbox rendering to my HS20 via Dscaler so I stick on 50Hz and all is well.
    However I wonder if I am at a disadvantage on Live games. (did ok the other night though).
  12. Zapp.Brannigan
    Zapp.Brannigan
    Jul 14, 2003
    169
    Manston, Ramsgate
    +3
    Thanks for that Mr. D. I must have missed that bit! :blush:
  13. adam*B
    adam*B
    Should we be setting our XBOX's to 50hz then ? A la Halo 1, so to speak ?
  14. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    Not necessarily : its more symptomatic of the 56Hz refresh rate on my HS20 . Halo2 runs fine in 60Hz on my plasma which is 60Hz native (without any remapping) The 56Hz refresh on the HS20 seems to make 30fps material (which is what I suspect the Xbox is rendering ) drop frames so it stutters badly even ingame.
    I've been playing mostly in 50Hz though as a result. I'm wondering if you get an advantage in Live games at 60Hz relative to 50Hz though.
  15. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Also get the graphics pop in - it is due to the game streaming off the HD / DVD drive thats why theres no loading. Play Riddick it uses a similar graphic tech as halo 2 but has no graphic pop in BUT suffers from some long load times.
  16. Rawschach
    Rawschach
    Nov 8, 2004
    1,399
    116
    sunny halifax
    +1,012
    the bit with the muffled sound i think is deliberate because you go through an airlock and outside the spaceship into space - i thought it was a great effect
  17. masterofimages
    masterofimages
    Dec 1, 2002
    110
    Southend-on-Sea, Essex
    +3
    Although, strictly speaking you shouldn't be able to hear anything at all! :lesson:
    You can tell that one of my favourite shows is Firefly :D
  18. Zapp.Brannigan
    Zapp.Brannigan
    Jul 14, 2003
    169
    Manston, Ramsgate
    +3
    Surely you could hear yourself breathing in the armoured suit? Or farting, if you're being shot at.
