Halo 2 save points (bought it for my 360)
j_s
I picked this up a little while ago for my 360 but i've never noticed until the other night in single player campaign mode if you can save only at the complete level start or at save checkpoints. The reason I ask is I was playing as the Arbiter and got to the first flood section where you keep going down until you reach the bottom of a sort of large shaft (it takes forever). I forgot to save at that point and turned the 360 off but assumed (wrongly) that it would save at certain points automatically. I assume it only saves automatically when a level is complete rather than sections of the level?
S
SquintingBadger
You have to select Save & Quit from the menu IIRC and it will save from your last checkpoint.
j_s
Thanks for that, I know it's an old game now, I'm just getting the single player out of the way and then on to new 360 games then :)
