Halo 1 help with saves
Discussion in 'Nintendo Forums' started by CatManDo, Nov 13, 2004.
  1. CatManDo
    CatManDo
    Nov 5, 2003
    1,787
    South Yorks
    +248
    Being a newbie XBox owner I am playing Halo 1 at the mo.
    When I switch off and go back to a saved game later I seem to go 2 or 3
    checkpoints back of where I was! Is your progress not saved at each
    checkpoint or am I doing something wrong?!
    Please help!
  2. nealgs
    nealgs
    IIRC i think you have to do an actual save in order for you to keep progress current.
    If you just turn of the xbox without saving, you will only have the last save you did as you current position
    if that makes any sense
    regards
    Gary
  3. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,926
    2
    Manchester
    +4,449
    When you've finished playing that bit of the game you want to, press Start and select 'Save and Quit'. It won't save your last checkpoint unless you do this.
  4. CatManDo
    CatManDo
    Nov 5, 2003
    1,787
    South Yorks
    +248
    Yeah you were right guys :)
    Sorry for being such a dumb ass
