halloween 3 ( season of the witch)
Discussion in 'Movie Forum' started by harris87, Mar 24, 2001.
  1. harris87
    harris87
    Mar 17, 2001
    35
    united kingdom
    has anyone puchased this region 2 disc.
    the reason being i have found a very serious flaw with it.
    the disc is supposed to be in stereo,but in fact the sound only comes out of one channel(left channel only).
    if anyone has got the same problem,please post a reply and let me know.
  2. Mark P
    Mark P
    i have halloween 3 on region 1 dvd, and its only in (1 channel MONO) as well, but it does state this on the box. You will probably find this is a Missprint on the region 2 cover...........but still a good film, (very underated)
    hope this is of some help
    mark p.
  3. Guest
    harris 87,
    I have a disc like this(not the same title)that claims it is in stereo and mono but when you just insert it into the player it plays out of the left front speaker in stereo.So I went back to the dvd disc menu and selected mono instead which sounded a lot better because the sound came out of the centre speaker.Worth a try if you have got this option.
    regards
    martinc
