norfbech
Established Member
Hi all,
Has anyone had any experience of those multiple recessed downlights as per below:
Mulitple recessed Lights.
I've purchased around 10 fire rated downlights which I'll split over two reception rooms (ceilings are currently down), but I've seen a lot of these of late...and I really like the look. These particular ones (as an example) are GU10's, but I'm hoping to replace with LED's (have installed some outside and I'm really pleased with them).
Pretty sure (looking at the attached documentation and the fact they are enclosed) they are fire rated. They have to be as for the hall, I'm adding a drop ceiling which may or may not be made from MDF (the lower drop section). Speaking with someone who installs these type of ceilings for a living suggested that over another layer of Plasterboard.
This is a rough mock up of the ceiling in question (not at all to scale - approx 3.5m x 1.8m, but there is the cut out section where the stairs are). Could possibly have a set of three followed by either a set of two or a couple of single ones....it's not a large hall by any means.
Really after a bit of info from anyone who has used them in a similar situation (or any situation to be fair).
Many thanks.
Many thanks.
