HALF LIFE 2- WIll it work on ....
Discussion in 'General Video Gaming Chat' started by JiMbOb_74, Nov 19, 2004.
  1. JiMbOb_74
    JiMbOb_74
    I have an AMD 2000+ (1667mhz) running an old 9200 radeon 32m with 1/2gig of mem(non DDR)
    Anyone have any idea how Half life 2 will run if at all...
    Halo 2 finished need more shooting of aliens!
    please any help!
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    the graphics card looks a bit shaky, I'd try it on low and see what happens.
  3. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I have a similar spec machine except the graphics card i have has 128mb of ram and on medium settings it runs not too bad.
    Your video card as Games Guru says is likely to be your stumbling block.
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,988
    167
    The Wheldon Road end!
    +8,132
    Yeah if you can pick up a decent TI GF4 (2nd hand they should be peanuts now) then you should be able to play it OK but I doubt that a 32meg card will cut it. The rest isn't too bad i'm only running an XP 2200+ and 512 meg 400mhz ram with a Ti4400 - runs a treat! :thumbsup:
  5. JiMbOb_74
    JiMbOb_74
    Thnaks for the help guys...will upgrade machine before buying the game then!
