Half-Life 2 Installing/Re-Installing Query
Discussion in 'PC Gaming & Rigs' started by LiquidTV, Jan 10, 2005.
  1. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Having had this game since Xmas, I have only just got around to installing. What a complete pain in the arse!! :thumbsdow I couldn't believe the trouble I had to go through to get it to work. I've still got crappy 56K modem. After several attempts, in all it took 3 hours of fiddling about before it would finally work. The key to making it work offline I found, was blocking it in XP firewall. Anyway, I'm sure it'll be worth it.
    The point of my thread is that shortly I will be able to finally get broadband where I live. When it finally arrives, I am planning on a complete re-format of the hard drive to remove unwanted rubbish & address various issues that I have discovered since the first install of XP2. I have obviously created a steam account to make this damn game work, but will I be able to re-install??
    My understanding is that the CD key is linked to the account. I also read this must be accessed at least once a month to keep it open?? I assume if I don't & try a fresh install I could run into problems.
  2. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    i think you'll be ok. I'm assuming you can just type in your user name and password again. i agree though intallation was a seious pain in the backside.
    mark
  3. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +432
    yep - just make sure you have your Steam username / email address used / password ...... and any keys that you used to hand.
  4. Loon
    Loon
    When you re-install you just need to put Steam back onto the machine. It will ask for the account details so just enter the same as you did before. When you re-install the game it will ask for the CD key again. When you enter it you get a message telling you this one is already in use so just hit cancel and it should work. You could probably just hit cancel and log into Steam but I have never tried it that way.
    As for the logging into it once a month I have never heard this. I have my Steam account ever since they made us use them and have never had any problems with it. I have gone months without using it so I think that might be an old wives tale.
    Hope you enjoy the game as much as I did.
    Loon
