Half decent cable and lengths
Discussion in 'Home Cinema Speakers' started by slyborg, Aug 18, 2003.
  1. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Having decided on the B&W VM1 speakers and a Pio VSX-D2011-S amp I'm looking for some cable and good online stores. I've done the obligatory search and noted that I can use cheaper cable for the rears. In total I need about 30 metres approx 10 for front 3 and 20 for rear. I'm also assuming something I read ages ago is true in that you should keep speaker cable lengths the same for pairs of speakers. I also read about biwire in some of the search results but am unsure as to what that exactly is. So if anyone has a good online store and some advice on half decent cable (I'm not a huge audiophile so half decent will do me fine) it would be much appreciated.
    Si
