Haier P42LV6 anyone know about this plasma?
Discussion in 'Plasma TVs Forum' started by 999dom999, Aug 16, 2005.
  1. 999dom999
    999dom999
    Aug 10, 2005
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X3Jldmlld3M=&product_uid=91680
    Ebuyer are selling this plasma at an amazing price and the spec looks pretty good but does anyone have any knowledge of this screen is it as good as they reckon in the few reviews on the ebuyer site?
    So tempted but don't want to take the risk!
    Specification:
    Size: 42” wide-Brightness: 1000 cd/m2
    Contrast ratio: 5000:1
    Supported in Resolution: 1920*1080
    Technical features
    Item P42LV6-T1
    Size 42" Wide(16:9)
    Resolution 852*480
    Brightness 1000 cd/m2
    Contrast Ratio 5000:1
    Viewing Angle H:160°, V:160°
    Response Time
    Supported Colors 16.7M Colors
    Horizontal Frequency 31.47KHz
    Vertical Frequency 60 Hz
    Input Resolution(Max.) 1024*768 @60Hz (Analog) - 1920*1080 @60Hz (Digital)
    Input Signal Type RGB Analog/Digital(Separate, Composite, Digital)
    Connector 15 Pin D-sub/DVI/Component/S-video/AV/RS232/RF/SCART*2
    Power Supply 150-240V (50/60Hz), Built in Type
    Dimension (W*D*H) Net: 1050*86*664 mm - Gross: 1155*355*785 mm (without stand)
    Weight Net:35KG, Gross:40KG Wall/Arm Mount Type Custom
    Multimedia PIP (PC Mode) / PBP (PC Mode), Zoom, Freeze
    Remote control
    NICAM, Fastext
    Accessories Optional speaker (7W*2EA)
    Optional Stand/Wall mount
    working Less than 380 watts
    Standby Less than 4 watts
    Languages English / Italian / French / Spanish / Germany
  2. samcressy
    samcressy
    I finally took the plunge and ordered one it arriving on Tuesday. I'm a bit nervous as to whether it will be any good or not but will let you know the outcome. If not it's going straight back!
    FYI from the specs is seems to be EDTV not HDTV which isn't a concern to me anyway.
  3. 999dom999
    999dom999
    Aug 10, 2005
    Thanks for being the Guinea pig, let us know how it goes I'm so tempted!
  4. mskim
    mskim
    Nov 17, 2004
    48
    OK
    How good or bad is it.
  5. hoodga
    hoodga
    Aug 19, 2005
    80
    anyone got any more info on these and what there like thinking about one
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I would be more worried about how they ship it. If it's by City Link, I wouldn't want to rate your chances of it arriving intact. Many of my Ebuyer deliveries arrive with hob-nail boot marks on the boxes :eek:
  7. 999dom999
    999dom999
    Aug 10, 2005
  8. 999dom999
    999dom999
    Aug 10, 2005
    Dam just seen that ebuyer no longer has this on special offer, it was 899.00 now it is 969.99, at the time I started this thread there were 134 in stock now 65, so they are selling pretty good!!!
  9. 999dom999
    999dom999
    Aug 10, 2005
    Well???????????? :)
    Did it turn up??
    Initial impressions???
  10. samcressy
    samcressy
    Sorry about the delay 999dom999. The plasma arrived on Tuesday in very good condition - no boot marks etc! My first impressions are that the quality is excellent crisp and clear even watching Sky via scart. I played Lord of the Rings last night using progressive scan and the image was nearly faultless. It has PIP, supports the different progressive and interlaced resolutions as in the spec but it will down convert these to 852*480. It also has all the inputs and outputs you could ever need except it doesn't have HDMI which aparently Sky will be using for it's HDTV service. I haven't tried connecting a PC yet but my PC doesn't have DVI so I can't test it to it's limits anyway.
    I have not had a lot of experience looking at different plasmas to compare the difference but I can definately say that I am very happy with my purchase. I must admit however that the £899 price was what convinced me it's a shame it's gone up again.
    If you have any other questions let me know.
  11. zonemikey
    zonemikey
    Aug 25, 2005
    Hi samcressy,
    Seriously thinking of getting one of these bad boys....
    My only concern is the speakers (7W x 2) seems a little weak...
    Is this the case ??
    Also, what do the speakers look like ? Are they attached to the plasma or are they free standing ?
    Many Thanks in advance.
  12. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Guys, do some Googling. First check out this thread : http://forums.overclockers.co.uk/showthread.php?p=5420678#post5420678
    It's an SD (Standard Definition) screen that can 'support' (ie. downsample) higher res content - just like they all can.
    It has DVI - but crucially, no HDMI (so no copy-protected SKY HD content will display). And it doesn't support native at 50MHz, either.
    Why get this rather than a PWD7 or a PE50?
  13. samcressy
    samcressy
    Hi zonemikey
    The speakers do mount on the sides and look quite nice. I haven't fiddled with the sound settings yet (I am using a Denon SD500 home cinema for sound) but from what I've heard from the speakers the sound quality is pretty poor with no bass. If you don't have a decent sound setup take this into consideration.
    Sulis to be honest I will be returning to Australia around the time Sky HDTV comes in so won't need HDMI anyway. To anyone who will be wanting to use sky's new HDTV service later in the year I would look somewhere else because I believe that you will have a problem with copy protection if you try and convert the signal.
  14. zonemikey
    zonemikey
    Aug 25, 2005
    Thanks for your help.
    Think I'll go for it.......... :thumbsup:
  15. zonemikey
    zonemikey
    Aug 25, 2005
    Just taken delivery of my new Haier Plasma...... It's awesome :smashin:
    Does anyone know the NTL remote code for this Plasma. Would be nice to use one remote instead of two ????
    thanks in advance
  16. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    Hi all
    I have taken the plunge and bought this plasma from ebuyer. the picture is superb! however from the moment i turned it on it has a rather loud noise coming from the back, i thought it would probably go in time but now it is louder than ever! when the screen is dark its not so audible but when it goes bright it is very distracting and as it gets warmed up it can start to give me a headache!. The noise is a bit like a large florrecent strip light that is on its way out, at times i can even hear it in the room next door! This cant be normal, could you tell me if yours gives off the same noise? im thinking of returning it. If it wasnt for this i would buy another so any response would be gratefully received. Ive only had for three days
  17. zonemikey
    zonemikey
    Aug 25, 2005
    darrenjames,
    This is by no means normal...
    If you mute the Haier Plasma it should make NO noise at all. It is a fan free plasma... Mine is as quiet as when it is off...
    I suggest you send it back.
    Hope this helps.
  18. samcressy
    samcressy
    Hi darrenjames
    My Plasma does the same thing. It seems to be the power supply or something else at the back which is noisy. Anybody else having the same problem?
  19. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    thanks all!!
    Ive decided to return my plasma. Shame though, i love the picture! just cant live with the noise. Any way life is a bitch!. I dont know if to risk getting another (if they have got any left) or to choose another plasma. Like i said i love the picture and most of the other plasmas ive seen (around the £1000 mark) are dogs in comparison.
  20. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    by the way Samcressy, is your plasma a haier p42lv6?
  21. cdpdesign
    cdpdesign
    Aug 31, 2005
    13
    I've had a panasonic 42" viera since last christmas. I was very impressed with the TV Excellent picture, fantastic looking piece of equipment, etc... But VERY POOR SOUND QUALITY! When you look at paying £3k for a tv then you would expect it to be like being at the cinema! lol
    I connected the panasonic up through a 5.1 surround sound system and muted the sound on the TV, and then IT was faultless.... UNTIL....
    I split up with my Girlfriend and she chose to take the tv! lol
    So I went onto Ebuyer and bought the Haier P42LV6
    My comparisons so far:
    Not as good build quality, ie materials used, but still good
    sound pretty similar
    Picture seems BETTER on the Haier
    Haier was £2500 cheaper (got it for £949.99 Delivered!!!)
    So I would go for the Haier!
    Incidentally, on the box and the literature, it states "HDTV Ready" so there may be some trading standards issues there; I cannot legitimately quote on this as I haven't looked into it, and to be honest, when Sky start their new service, it's going to be probably so damn expensive, it won't be worth it anyway.
    The picture is so crisp, I can't see how it could get any better to be honest!
    So if you had any doubts, I hope that this has settled your mind!
  22. samcressy
    samcressy
    Yes darrenjames it is a haier p42lv6. The noise I'm getting isn't all that loud but still is a concern.
  23. zonemikey
    zonemikey
    Aug 25, 2005
    Guys,
    Mine is a haier p42lv6 too and like I said before it is as quiet as when it is off !!
    Send it back.....
