Had enough!
D
Dozer
Well that’s it! I’ve finally had enough of the Sharp vcr/dvd combo unit I’ve got – useless p.o.s.
VCR side is fine but the dvd aspect is [email protected], it only plays what it feels like on the day. As opposed to the £20 Alba system in the office that plays anything thrown at it!
So, time for a new one –
Progressive scan
Component output
Multi region
+R and –R and all permutations of them
and all for under £100, so any suggestions?
Have seen this at Maplins and with a discount should be under £50, anyone with any thoughts or suggestions?
http://www.maplin.co.uk/Module.aspx?ModuleNo=45562&doy=26m9D
Will be connecting to my TH42PE50 via Monster THX component cable and RGB scart
the mechanic
Hi there dozer,
May I suggest THIS FINE MACHINE here. Has many fans on the forums (me included), plays the formats you require plus DVD-A and SACD, MR outta the box AND has great audio / picture quality.
Though component in prog scan (PAL & NTSC) on my Toshiba zp48, the PQ is amazing.
IMHO its cheap at twice the price.... :clap: ....
Graham.
supermackem
I would third that i have two best dvd player i have ever bought.
