Had a Panny PE37, replaced it with a...........
Discussion in 'Plasma TVs Forum' started by highlander_777, Aug 18, 2004.
  1. highlander_777
    highlander_777
    Apr 4, 2004
    216
    Sony KDEP37XS1 37. The panny was good but the SONY is better :thumbsup:
    The sony has a better pic and looks better. glad I changed it :smashin:
  2. pauljbent
    pauljbent
    Out of curiousity where did you get it from? I'm eyeing them up myself but theres no way I am paying the £3300 that Sony shops want or £3600 that John Lewis want (JL refused to pricematch AJ Electronics at £2600 because its a "warehouse"????)
  3. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    How long did you have the Panny before you changed it, and what did you say the reason was?
    I am having the same thoughts as you but am having difficulty exchaging.
  4. highlander_777
    highlander_777
    Apr 4, 2004
    216
    I went to JL Watford and they did a price match at Hi-spek in St Albans. They have a web site www.hispek.com. I got it for £2750
    I had the panny for 25 days and it developed a fault, loose wire. So I took it back to the shop and said under the goods and sevices act 2002 I would like a full refund as the good were faulty when I bought the plasma :thumbsup:
  5. pauljbent
    pauljbent
    :thumbsup: Interesting, £2800 was my top price at JL and only because of the warranty, I may go visit JL Cribbs Causeway armed with this information, thanks.
  6. pauljbent
    pauljbent
    We went, we talked, they said yes :) , we bought :eek: , Delivery on Wednesday. I'm home now and I've just got to find a wall bracket for it.
    Thanks for the price compare from Hi Spek, they phoned them up and came back with an agreement in less than 10 minutes.
