Hackz for hitachi dv-p515e
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by myrtle, Sep 5, 2001.
  1. myrtle
    myrtle
    Has any one got any hackz for my dvd player (dv-p515e)<br />All help would be greatfull
    Code:
      </pre><hr></blockquote>  <img src="confused.gif" border="0">
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Always perform a Cold Start before applying the hack below <br />1. Power on your player <br />2. Press and hold both the Play and Stop buttons on the player <br />3. After a short while you should be presented with a set of language options. Release the Play and Stop buttons on the player <br />4. You will now need to select a language option between 1 and 6 <br /> To convert this player to Multi-Region playback <br />1. Press the Repeat button on your remote control <br />2. Using your remote control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate <br />for Region 1 use 2, 9, 3, 3 and 4 <br />for Region 2 use 3, 8, 7, 6 and 7 <br />for Region 3 use 5, 6, 7, 3 and 2 <br />for Region 4 use 7, 6, 8, 8 and 4 <br />for Region 5 use 5, 3, 8, 1 and 4 <br />for Region 6 use 2, 4, 4, 6 and 2<br /> <br />3. A code should be displayed on the screen indicating the current Region setting of your unit. <br />4. Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on. <br />5. Press the Open button on your player <br />6. Press the Standby button on your remote control <br /> If the player sticks on FBI Warning screens <br />1. Press Forward Search x2 or faster, the disc should skip straight to the main feature
