Hacked already ......
Discussion in 'Nintendo Forums' started by John, Apr 7, 2005.
  1. John
    John
    Dec 13, 2002
    11,303
    +2,921
    The Sony PSP , see here
    Its probably been mentioned in the PSP thread , but feel it probably deserves one of its own
    JS
  2. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    I suppose it was bound to happen sooner or later. Still, it may speed up the release of the official web browser, which is rumoured to be late May now.
  3. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    How much does it cost to go wireless in the home? I have an xbox live downstairs, and my pc, and would like the psp hooked up as well. Is it expensive to do?
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    Land of the Living, Essex
    +44
    The DS is free o I'd assume the PSP will be too
  5. Kube
    Kube
    Mar 21, 2005
    5,375
    Armagh
    +369
    Its good to see all this development for the PSP. Its a powerful piece of kit and should have no problem running any of the software developed for it. A good sized memory card will be needed for the future though methinks.
  6. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    Na, pretty cheap fella. A wireless router is between £30 - £50 and that's all you'd need! Keep your PC & X-Box hard wired and use your PSP wireless. If you want your PC in another room wireless then you'll need a wireless network card for it and if you wanted your XB wireless in another room you'd need a wireless ethernet bridge.
    I'd recommend Linksys's routers, the wireless G is £50 and the wireless B is £35 at amazon but you may get them cheaper elsewhere. Unless you're moving a lot of data around the network then the wireless B is sufficient and gaming speeds are not reduced.
    Hope that helps :thumbsup:
  7. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Yea I have the Linkysys wireless G router. Its a great pirce of Kit. I cant get it to work with the PSP though it wont take my 64bit encyption key :(
    Gthom have are you using this router ? How did you get it to work. It find the network no problems but says my 10 charcter key is invalid. weird....
    If so how did you get it to work. It was obvious they would crack PSP I am suprised it was so quick though. Expect region free UMD and many many emulators to be available shortly :)
  8. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    Especially with the 2gb pro duo cards soon, bobs your uncle.
  9. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
  10. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    trying to get your post count up mate?
  11. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    Are you? :D
    I have'nt really read anything on the psp can someone tell me when its out here & how much? gthom3 is pes gonna come out on the psp? i'm asking you cos i know you will have already looked into it. :rotfl:
  12. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Naaaaaa just for people who can be arsed or dont see the link.
  13. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    should be out 3rd quarter in Europe, is out now in North America and Asia.
    do a search for it online mate, loads of info.
  14. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    :hiya: :rotfl:
  15. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    Could'nt be bothered doing a search for the answer to that so i just asked you .;)
    Thanks anyway
  16. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,369
    I don't use an encryption key on mine which is a bit risky I guess but i'd soon know if someone else was using the connection. I just scanned and it picked it up and set up the connection straight away.
  17. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Its picks up mine no problem but wont take the wep key. A few people have had this problem I think its down to compatability with the router.
    I cant risk my network being open. I can browse the net at the end of the road using my connection (50 M minimum) half the neighbourhood could easily share my connection.
  18. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    I think alot of the issues people are having with WEP will be solved when the official browser is released, while it is good that people are finding roundabout ways to go online, IRC and even AIM can be accessed, I feel that it should be taken into account it's still early days with the PSP.
    I think I also read somewhere that it's something like a 13 digit WEP Key the PSP currently accepts, a 10 or 26 key will cause the problems people are getting. Rumour has it that it's late MAY for the next PSP system update, and that's when browsing and possibly email appears.
    The comment about region free UMD while interesting, will probably not happen. I read somewhere that only Sony themselves can press to UMD, they have not licensed the hardware to do this to other pressing/duplication plants. The line about this I read was "to try and reduce piracy, with the knowledge only Sony can do this"
    So any company producing games for the PSP have to go to Sony to actually get the game made.
    I don't know how many people visit www.sony.com(USA Site) but there is a very active PSP forum there, which I got some of this information from.
