Hack required for Toshiba RD-XS32SB
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Member 38491, Jun 30, 2004.
  1. Member 38491
    Member 38491
    Dear All
    I have just bought the new Toshiba "RD-XS32SB" from Costco.
    Could you please advise me of the multi region hack for the above machine and any other interesting information that you think may be relevant.
    Kind Regards
    Huddy
  2. Oggy_Steve
    Oggy_Steve
    Jun 11, 2006
    12
    3
    Hi I've had the Toshiba for about a year now and its great for recording and watching DVD's. I find it a little complicated, but I don't read manuals which may help.
    My issue at the moment is I can't use the Handset to operate the player, it just pops DR2 on the Display but nothing happens.
    I've also read about Handset hacks and wondered what this means.
  3. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    There is a remote hack listed here and also on the Videohelp website and other places, but I have tried it several times and it didn't work for me.
    The only person for whom the hack seems to have worked was playing an R4 disk on an R2 machine, and this you can normally do anyway as R4 disks are usually R2 compatible.
