Originally posted by Harri2000
Is there such a thing as a multiregion Hack for DVD players that you get on your PC?
Yes.
There's a couple of ways you can do this.
Download a free program off the net something like DVD Genie, this allows you to modify the region code for popular software-based DVD Players including such players as Software Cinemaster, PowerDVD.
or
Go into the the files/menu that are associated with the dvd thats on your pc, on mine it was a set up file which allowed you to change the region code from 1 - 6, some will only allow you to change it so many times before it locks on your last choice, if in doubt go for the first option.
