Hack needed for Humax dv1000t
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by BIGDAZ, Nov 4, 2004.
  1. BIGDAZ
    BIGDAZ
    Sep 7, 2004
    7
    Hi does anyone know how to make this player multi region. Humax have given me a method but it doesn't work.
    Any help greatly appreciated. :lease:
  2. BIGDAZ
    BIGDAZ
    Sep 7, 2004
    7
    I have managed to fix my own problem. Heres the method for anyone how might be interested
    1. Switch to DVD mode
    2. Press 'Menu' Key on the Remote control
    3. Go to the Parental Control Menu (You will be prompted to enter your
    password)
    4. Press number '4' key
    5. Press the following coloured buttons: Red--> Green--> Yellow-->Blue -
    6. A small box will appear to the R/H of 'Parental Control header' with a number in it ( mine was '0' but it wasn't multi region)
    7. Then press key '9'-'6'-'3'-'x' - ( I used '0')
    a. x: region code
    b. 0: all free
    c. 1~8: region code
    8. Then press the standby button.
    9. switch unit back on and use above method to show region and now it should have an 'A' in it. (all regions I suppose)
    Sorted :clap:
