hack needed for DK DVD-500
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by sukanat, Sep 1, 2005.
  1. sukanat
    sukanat
    Does anyone have a hack for the DK DVD-500?
    I've the hack listed for other DK models, but mine doesn't have a 'clear' button. Any suggestions? Thanks
  2. mat1980uk
    mat1980uk
    Apr 29, 2005
    70
    11
    walsall, west midlands
    +17
    hi there is a hack for this model .also just to let you know there is a dedicated forum for this model at www.dkdigitalelectronics.co.uk where you be able to get more info on it and there is alot of info ! as well as a long long list of faults check it out you will see what i mean ! and incase you wondering i do have a dk digital 500 Any way the hack is as follows -:
    Switch on the DivX Player using the remote control
    Press OPEN button on the remote
    Use numeric keys to enter 1030 followed by
    0 for the region code,0 (multi-Region)
    The TV OSD will show "0" in a short time
    or number for a specific region i.e 1 for region 1, 2 for region 2 etc
    This works with the majority of RCE protected discs. If a Region disc fails to work, set the player to the same region of the disc insertd
