Hack Needed for "Denon 2800 MK2"
A
amrik7777
Hi Guys, Just registered today. I have recently purchased a Denon 2800 MK2, however, it only plays Region 1 Discs.
Does anyone know of any hacks to make the DVD Player Multi Region?
I would greatly appreciate your help.
Thanks. Amrik.
Hackeroonie
Amrik7777
I thinkYour Player needs a Firmware Upgrade....not sure if it will work on a R1 Model some Denon Upgrades won't
Have a look here ...How is your Italian ?
http://www.afdigitale.it/DownloadNavigation.aspx?cat=Firmware DVD Video
It is up to you if you want to try it ...provided you can translate the Page
Unless someone knows an English Language Link....or if the Firmware Upgrades for Multi Region work on R1 Players.
Hackeroonie
A
amrik7777
You was right. I needed a firmware upgrade. I ordered the firmware disk from www.multi-region.co.uk. It cost 19.99. The Denon now plays all DVD's.
Thanks for your advice.
