Hack for Yamaha E600 DVD
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by SUNSCREAM, Dec 19, 2004.
  1. SUNSCREAM
    SUNSCREAM
  2. lordko
    lordko
    Apr 11, 2005
    Any news on that? I looked on Google and couldn't find any way to make the Yamaha E600 region free!
    Hope someone knows :-D
    Thanks!
  3. rosco26
    rosco26
    eventually found this but don't know if it works...
    Region code hack posted by ettgec, July 24 2005:
    1) power up the unit as normal
    2) open tray
    3) enter 99990 with remote
    a message will appear on the tv "region 0"
    4) press enter & close tray
    works instantly
    * by changing the end number you can reset the region ie 99991 would be region 1 ect
    N.B. This is the same hack as with the Yamaha C750
  4. Liberator
    Liberator
    Nov 22, 2005
    22
    3
    Open the tray, then with R/C type: '99990 Enter'.
    Turn unit off, then on again. Done!
  5. garymv
    garymv
