Hack for Yamaha DVX S200?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by grunners, Dec 22, 2004.
  1. grunners
    grunners
    Can this system be hacked via a remote or do I need to pay to have it done?
  2. andywilks
    andywilks
    I believe it can be remote hacked- but I haven;t got the instructions yet- only for the SX120- I'll send them to you when back at work AW
  3. andywilks
    andywilks
    OK have just tested this on a DVXS200- works ok. instructions were for the DVXS120
    turn unit off
    hold ABCDE key and turn unit on (STBY key)
    then within 3 secs press memory key. display says Diag mode
    press SKIP >>I (to right of play button)
    press DVD/CD button
    press shift and 8 buttons together
    press SKIP>>I until Vermatrix appears
    Press PLAY key says Vermatrix INIT
    (didn't seem to need this next bit on a 200 so disregard- may need it for the 120? press skip to get vermatrix again- the shift+ 7- init reappears)
    continue..
    keep pressing skip until F(0) appears press play
    are you sure? appears press play again
    wait 20 secs appears- WAIT!! writing to eeprom in progress-- display doesn't change!
    then turn off, back on and its multiregion
    the orig instructions are like a translation from japanese so interpretation was difficult.- just be careful not to set anything that you don't understand!!! I won't be held responsible.
    there are other options you can set in tvsetup menu like pal/ntsc YUV etc- but I presume these can be set using normal menus.
    Good luck AW
  4. surferrosa17
    surferrosa17
    Have a DVXS120 but cant get as far as Diag mode with your instructions. Any suggestions? Cheers
  5. andywilks
    andywilks
    If you can't even get to diag mode then perhaps check the following: make sure theres no disc in unit. use just the buttons on the main unit, I think you release ABCDE key after turning power on before pressing memory key, but try it both ways. give good length button pushes to allow system to register keypress.... good luck.. AW
  6. surferrosa17
    surferrosa17
    Worked! Thanks a lot mate!
