Hack for the Yamaha DVX-S120.....PLEASE!
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Don.Dada, Jul 14, 2004.
  1. Don.Dada
    Don.Dada
    Hi, Yamaha UK told me there is a remote hack for the Yamaha DVX-S120 but legally can not give it to me. Can someone out there help me :lease:
  2. Silverfox
    Silverfox
    :lesson: Picked this up from a mate at Dixon's who said it definitely works.
    PLAY: Enter key
    STOP: Escape key
    Skip+/-: Select root menu
    1. Turn off the system
    2. Push the "A/B/C/D/E" key with "STANDBY/ON" key pushed simultaneously.
    3. Then push "MEMORY" key within 3sec.
    4. Front display will now show "DVD DiagMode and few seconds after display [Ver.Disp]
    If you push Skip key the display will show [Ver.Disp] or [TV Setup]
    5. On the Remote control push DVD/CD key
    6. Push "shift" + "8"(A-B) keys simultaneously.
    If push Skip key display show [Ver.Disp] or [TV Setup] or [Ver. Matrix]
    7. Select [Ver. Matrix] menu and push PLAY key display shows VerMatx>Init
    If push Skip key display show VerMatx>Init, VerMatx>
    8. Select [Ver. Matrix] menu, Push "shift" + "7"(REPEAT) keys simultaneously.
    Now appear VerMatx>Init, VerMatx>U(1),>G(2),>J(2),>K(3),>L(3),>R(3),>A(4),>T(6),F(0)
    9. VerMatx>F(0) display and push PLAY key.
    10.It will ask "Are you sure?" push PLAY. The unit will now change to region "0"
  3. Don.Dada
    Don.Dada
    :thumbsup:
    Thanks Silverfox, an awkward hack to implement but it worked. Tested r1,3 & 4 discs no problems……Thanks :clap:
  4. treenybean
    treenybean
    This didn't work for me as the f(0) option was missing on my machine. However on another site I found:
    1/ Power ON
    2/ Press PLAY
    3/ press 2 7 4 2 2 2 2 2 2 0 0 5 2 5 5
    4/ Press Play
    5/ Power OFF
    And it worked!!
    Hope this helps someone.:clap:
