hack for Tevion DVP7011 anyone?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by hard-man-stan, Jul 8, 2004.
  1. hard-man-stan
    hard-man-stan
    Just bought Tevion portable dvd player from Aldi - £159.99 seems to be vg value. Only plays region 2 anyone know hack for region 1
  2. Aqualung
    Aqualung
    Sep 12, 2000
    45
    The Tevion DVP7011, from ALDI is an Audiovox D1708PK 7" 16:9 Slim Line Portable DVD Player.
    Features: High Capacity Rechargeable Battery, Digital Out, Built-In Stereo Speakers, Cigarette Lighter Adapter w/ Complete Cabling, Plays DVD, CD, and MP3, "Credit Card' Size Wireless Remote.
    see it at www . audiovox.com
    Even the online downloadable manual is identical (barring ID and helpline No's).
    Unless the Audiovox machine is also a rebadged 'something else' there may be a hack somewhere for this machine that will work on the Tevion.
  3. Aqualung
    Aqualung
    Sep 12, 2000
    45
    It definitely is, my player is now region free with this hack:-
    1) Open the DVD Door, on remote press Setup, Right, Right, Right (that's the arrows in the middle of remote)
    2) Enter 9653,a service page will appear,
    3) Use Up/Down Bottom to change region Codes
    4) Set to 0 (zero) for multi-region
    :clap:
  4. hard-man-stan
    hard-man-stan
    Thanks Aqualung - mine's now region free :)
