Hack for Teac DR-L700
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mattblue, Sep 3, 2004.
  1. mattblue
    mattblue
    Could anyone advise on how to change the regions on the above DVD please, region 2 is just doing my head in :lease:
    Matt
  2. andywilks
    andywilks
    press open on main unit
    on remote clear 2 5 8 0 clear (quickly) test mode appears
    up triangle (^) fld shows 00 54
    ^ again 14 02
    0 0 enter fld shows 14 00
    ^ again 13 33
    7 3 enter fld 13 73
    ^ again 12 35
    7 3 enter 12 73
    return disp test mode
    return displ end
    main unit open/close tray closes
    on remote power off then on re-writing data is performed
    it should now be auto
    AW
  3. harry mungus
    harry mungus
    Could anyone please let me know if the DR-L700 is capible of playing PAL progressive scan ? :lease:
  4. pooh bear
    pooh bear
    I have the above mentioned DVD played from Teac. The procedure listed by AW works perfectly. I have just successfully executed it.:thumbsup:
    Thank you AW
    P.S. Out of interest, how did you come to know this?
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I also just changed mine and it worked... :thumbsup:
  6. markridoo
    markridoo
    I don't seem to have fld on my remote - could it be lablled as something else?
  7. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I think fld is the display... :smashin:
  8. markridoo
    markridoo
    Ok - thanks! :thumbsup:
  9. pawlakr
    pawlakr
    Mar 29, 2008
    Hi All,
    I have 2 of these, but one recently has gone faulty and wondered if anyone out there could help out? :lease:
    The DVD unit powers up with the blue leds and then goes off, then on, then off, over and over.Can anyone help?
    Regards Hog
  10. Quenby23
    Quenby23
    Mine is doing the same thing. I am advised by TEAC UK that this means it has gone into "PROTECT" mode, whatever that means. The people they suggested I talk to about repairs quoted £45 just to look at it, then if I decide to go ahead with repairs, that would go towards the cost. Hmmmm... Still deciding what to do.
  11. gotogolf
    gotogolf
    Dec 13, 2008
    Did you manage to solve this problem? I have the same issue.
