Hack for several players
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    This hack works with the following players : Aiwa XR-DV370KN
    most LG players : LG F-DV25, LG F-DV55, LG DA-5630, LG DC-593W, LG DC-593NW, LG DK-4821P, LG DK-8621P, LG DS-8400, LG LH6530, LG DVD-2000, LG DVD-2240N, LG DVD-2230, LG DVD-2300, LG DVD-2330P, LG DVD-2340, LG DVD-2380, LG DVD-3000, LG DVD-3200E, LG DVD-3230, LG DVD-3520, LG DVD-3530, LG DA-3530A, LG DVD-3350E, LG DVD-3351, LG DVD-3630A, LG DVD-4010, LG DVD-4210, LG DVD-4710, LG DVD-4721P, LG DVD-4730, LG DVD-4750, LG DVD-4830, LG DVD-4930, LG DVD-4950, LG DV-4941P, LG DVD-4950S, LG DVD-5500N, LG DVD-5500P, LG DV-5522, LG DV5942P, LG DVD-6812P, LG DVD-7711P, LG DV-7721P, LG DK-7821P, LG DVD-8621P
    Marantz DV3100, Marantz DV3100OSE, Marantz DV4200, Marantz DV6200, Nad L55, Nad T531, Zenith DVD2381
    * If the remote controls more than the DVD player, select DVD on the remote
    * Remove any disc, so 'No Disc' appears
    * Press Pause/Step and 314159
    * The display shows 'Code' or 'FF'. If not, Press Pause/Step, Enter and then 314159.
    * Press the relevant number button for desired region or 0 for all regions
    * Press the Pause/Step button again
    * Turn unit off with Power button. Power on again after 30 seconds and the machine will be set to the selected region.
  2. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    as subject:)
  3. dg42
    dg42
    May 6, 2006
    10
    Worked perfectly
  4. thirl123
    thirl123
    May 6, 2006
    26
    hi
    Stuart do you have the hack for a portable Ferguson ldvd81 that will alow me to play vcds
    thanks email me ([email protected])
  5. Keith35
    Keith35
    Dec 2, 2007
    2
    Is it likely that the NAD T531 hack will aalso work on the new NAD 535 please?
    regards,
    Keith
  6. cbautista1986
    cbautista1986
    Apr 12, 2012
    2
    hello
    I have a Marantz UD5005 Universal / Network Player and Zone 1 USA.
    I want to convert it to multizone or multiregion. Someone could help
    thanks
  7. jwlawler
    jwlawler
    Sep 20, 2007
    548
    28
    +32
    The first few digits of pi, there is a mathematician in the firmware programming team.
  8. cbautista1986
    cbautista1986
    Apr 12, 2012
    2
    thanks I will try what you say
