Hack for Samsung DVD-HR734
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by soosin1, Dec 18, 2006.
  1. soosin1
    soosin1
    Can anyone help a complete novice please. Have tried the Hack suggested by a member, but cannot seem to get it to work. What am I doing wrong??? Brand new unit plugged in tonight and followed the instructions below.......
    Make Sure Player Is Turned On Without Disc In Tray
    Press 'REPEAT'
    Press 5 7 5 3 8
    (You Will See 2 In Top Left Of Screen)
    Press 9
    (You Will Now See 9 In Top Left Of Screen)
    Open & Then Close Disc Tray
    That's It, Your Player Should Now Be Region Free
    I have pressed the REPEAT button, entered my code and nothing!! no sign of a 2 or anything else in the corner for that matter. It just doesn't work. Should the TV be switched on or off? Do I need to turn the unit off to try again? I really do feel like a bit of a plank, please can someone help a damsel in distress?
    I really would be so grateful.
    Sue
  2. Treadstone
    Treadstone
    Jun 4, 2006
    1,395
    48
    +46
    Be sure you're pressing the REPEAT button, and NOT REPEAT A-B. The button presses need to be done fairly quickly. HTH
