Hack for REOC A2
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Mitch2000, May 17, 2003.
  1. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Anyone found a Hack for this player yet. There not one listed yet on the usual sites.
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +220
    On a lot of the newer mediatek chipset based players the hack is the same. This hack works for about 100 different players it seems. From memory its turn on the machine without a dvd in the tray, then press setup, then 1369, then 3xleft on the directional keys and then once on the right direction key. That should give you a extra menu option then you select region 0. Note you have to cursor right to get on this option and then up/down to choose region 0. worth a try at least.
  3. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +220
    If my instructions aren't right just look for the hack for a cyberhome ch400 or ch402 dvd player .
