Hack for lots of players
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,821
    2
    167
    Birmingham, UK
    +9,559
    This hack works with the following players : Aiwa 50, Aiwa 520, Crown DVD, Dual DVD-810, Ferguson DVD400FE, Goodmans DVD-3000, Koss KD250, Matsui DVD-110, Matsui DVD-122, Matsui DVD-125, Medion MD-4364, Oritron DVD-100, Oritron DVD-1030, Oritron DVD-600, Proline DVD-2000, Schneider DVD-511, Tevion DVD-200, Thomson DTH-210E, Thomson DTH-220E
    1. Open the disc tray
    2. Press Menu, 167
    3. The display asks for a region. Press 1 for region 1, 2 for region 2 etc. or Mute (or 0) for multi-region
    4. Press Standby to power down the player, wait a few seconds and and then power it back up
    You may be able to enable VCD playback. Try:
    2. Place a music CD in the tray but leave it open
    3. Press Menu, 1, Index (1-All), Open and 1
  2. zoupie
    zoupie
    Does some know the region free code for Dual DVD-P 700 Twin.
    It is a portable DVD player with 2 screen and it is only playing zone 2. I would like to have it multi zone.
    Can someone help?
    Thanks,
    Zoupie
  3. billmono
    billmono
    u got macro hack for the goodmans gdvd301r? :)
  4. gooner18
    gooner18
    Nov 15, 2006
    7
    anyone know of a hack for Funai dvd recorder model DR-B2737.
    thanks gooner18
  5. yelselseivad
    yelselseivad
    Have tried 2 hacks which didn't work. the Press 8 , 2 , 1 ,3 , 9 + OK on the remote one and the for Region 2 use 3, 8, 7, 6 and 7 one but my dvd menu doesn't have system options on it so the first one doesn't work and the second one didn't either so does anyone have one that they've used on a 8640 that worked? Really desperate at this stage. Thanks
  6. aj2003
    aj2003
    Dec 8, 2008
    2
    I am looking for a multiregion hack for a Thomson DVT-8740. If anyone knows how to unlock this DVD player I would much appreciate it.
    :lease:
